What to check first ?
0 Members and 1 Guest are viewing this topic. Read 3585 times.
2bigears
« on: 5 Jul 2016, 01:28 am »
 :D. Hi everybody out there is the land of 33 1/3 .. A silly question here ,, but I really don't know. My digital is sounding better than my vinyl now and this just can't ve right. Is this a sign your cart is done or maybe the pre phono stage tubes if they have tubes ? I think my VAC Ren sig does ?  I don't know .  My table is the P9 and cart is X-2 Dyna-V.     I suspect the hours might be done on the tip. .
     I can't afford to replace this costly cart and loved it.  Has there been gains in quality and a lowering price as in most other areas ?  Just wondering ?  Thanks air ,, wondering which way to go ?  :D
gagamut
Re: What to check first ?
« Reply #1 on: 5 Jul 2016, 05:36 am »
your cart is it new??
may be you can try different loading.
neobop
  • BIRD LIVES
« Reply #2 on: 5 Jul 2016, 03:02 pm »
Hi,
Check the tubes first.
neo
2bigears
« Reply #3 on: 5 Jul 2016, 03:39 pm »
 :D  12 tubes altogether in this pre. it's most likely time. hope it don't hurt too much ??  8 - 12AX7 tubes, two lo noise.  2 - 8416 tubes and 2 - 12AU7's ......    do i need to buy VAC tubes or are these common valves ????   :D
mick wolfe
« Reply #4 on: 5 Jul 2016, 03:53 pm »
Soundsmith re-tips start at around $200. If you've determined the tubes are in good shape, I'd be looking at a re-tip from Soundsmith or The Needle Clinic.( Andy Kim) I think price range on either is in the $200-$400 range depending on stylus /cantilever choices.
Wayner
« Reply #5 on: 5 Jul 2016, 03:57 pm »
There are probably only 2 tubes in your phono section...no?
'ner
2bigears
« Reply #6 on: 5 Jul 2016, 04:06 pm »
 :D   no.  3 per channel and one low noise per channel.  lot of valves to replace..  :D
   you know if my digital sounds great,,,, that side must be good ??   6 tubes over there on the line side ,,,, :D
orientalexpress
« Reply #7 on: 5 Jul 2016, 07:19 pm »
Phono stage have it separate tubes .check that first
S Clark
« Reply #8 on: 5 Jul 2016, 08:06 pm »
  That's a $17K (list) preanp.  For that kind of change, call a dealer and ask them. They should provide amazingly good service.  At the least, they should check your tubes.
2bigears
« Reply #9 on: 6 Jul 2016, 01:43 am »
 :D. Maybe a belt on the TT first move.   I had no idea , 250 dollars ?  Good Lord  :D.  Rega Ref belt 272.00 holy shit ?
S Clark
« Reply #10 on: 6 Jul 2016, 03:02 am »
WHAT??? For a glorified rubber band?  Find an aftermarket or a DIY.
After looking, it seems that they are available for around $60... still too high, but not silly expensive.
2bigears
« Reply #11 on: 6 Jul 2016, 03:08 am »
 :D. An upgrade belt from Rega.  ,,,, but still,  On Amazon.ca.     I had no dam idea.  Must be cheaper alternatives out there.  :D
chili555
« Reply #12 on: 11 Jul 2016, 08:09 pm »
Your P9 deserves no less than this: http://www.musicdirect.com/p-11446-rega-reference-drive-belt-upgrade.aspx
I would also double-check the tracking force and the alignment. My Rega P25 preferred the Stevenson v.2 alignment from here: http://www.vinylengine.com/cartridge-alignment-protractors.shtml
