Sounds like a venting issue to me. Without proper sewer pipe venting, all kinds of weird things can happen. Air needs to come into the system to allow the water to drain away. Without it, the system will "burp" its way to drainage. Your toilet may be burping thru the flapper valve to get air.........'ner
House is a circa 1900 +/- three story single family converted to three apartments and then two condos. I occupy floors 2 and 3. Problem toilet is on the second floor. Kohler 2 piece 1.6 gallons per flush toilet. No plumbing changes of recent. The toilet and kitchen sink for the first floor are on the right side middleof the house. My kitchen is on the right side middle but the two toilets are on the left side. Vent pipe that sticks out the roof is on the left side of the house. At some point a washer dryer hookup was added to the third floor adjacent to the bathroom.
Not to *get* air, but to *release* air, yes? The flapper, in your example, has become the vent, thus burping (releasing) air. A flapper trying to *get* air would suction to a more-closed position, no?
Seems over pressure water in the pipe.
Drains in above grade situations are completely functional via gravity. There is no "pressure" present in drain systems as there is in supply lines.
I live in a building that seems to be the case, seems the OP live in a house.
I suppose I should clarify. I'm talking about residential plumbing in the US...such as a house.
Technically yes, but the air will want to come form wherever the path of least resistance is and can manifest in some odd ways.
Thanks. Not what I wanted to hear but what I needed to know. Can I live with it as is for a while or is this something that needs to be addressed pronto?
