NuPrime.. Polarity Reversal feature
0 Members and 1 Guest are viewing this topic. Read 3757 times.
Genez
« on: 1 Jul 2016, 06:14 pm »
Been searching....
Do any NuPrime DAC's include a Polarity Reversal feature?
rustydoglim
Re: NuPrime.. Polarity Reversal feature
« Reply #1 on: 1 Jul 2016, 06:19 pm »
No. I will bring this idea to R&D.
Genez
« Reply #2 on: 1 Jul 2016, 07:04 pm »
Thank you, sir!
I have been sitting on my current otherwise good sounding DAC while searching for something with that feature. One that is within reason. It will be my selling point.
Years back I heard the benefits with my old DacMagic.... though the DAC itself was not the best sounding, I was able to hear what a wonderful difference finding to right polarity would produce on different recordings.
Thanks,   Gene
JackD
« Reply #3 on: 1 Jul 2016, 07:16 pm »
Gene
If by polarity you mean phase inversion capability the W4S DAC-2's have it.
dwaleke
« Reply #4 on: 1 Jul 2016, 10:30 pm »
Or you could wire your speakers in reverse...
Genez
« Reply #5 on: 2 Jul 2016, 04:46 am »
I already do that.  Just had to listen to something in reverse polarity because its not convenient to get behind the speakers all the time....
Thanks..
Armaegis
« Reply #6 on: 2 Jul 2016, 08:48 am »
What are you using for source? If coming from a computer, some software programs have that feature too.
Genez
« Reply #7 on: 2 Jul 2016, 04:49 pm »
I am using a fanless SSD PC...
I might switch to J RIver as my media center. Though I find GOM Player to sound excellent.  Found out  that J River have hidden in the software a polarity option.  But, read its supposed to be cumbersome to get to. It was so easy when I had that feature sitting in front of me on my first DAC...
I contacted GOM and they told me they may look into the polarity feature. Hope its soon.
Genez
« Reply #8 on: 3 Jul 2016, 04:17 pm »
I forgot the main problem when using software....   Using different programs to channel music to the DAC will each have their own polarity.  I may use JRiver for certain things, things like streaming radio channels will go through their own dedicated software.  Having the control over polarity at the DAC covers all sources.
srb
« Reply #9 on: 3 Jul 2016, 04:31 pm »
JRiver has included a WDM Driver since v20 which can route all Windows programs sound through JRiver's DSP.
Genez
« Reply #10 on: 3 Jul 2016, 05:09 pm »
 I will be able to play videos, audio, and stream from the web all through the J River?  OK...   I got to learn more about this one.  Thanks!
