Well this seems rather strange, no?
0 Members and 1 Guest are viewing this topic. Read 1392 times.
Wind Chaser
« on: 28 Jun 2016, 06:53 pm »
I have an HSU mid bass module and on the back side control panel, there is a switch to set the phase at 0 or 180. With the tube amp, the bass is more robust and better defined with the phase set at 0. However, with the solid state amp, the bass is fuller and richer when positioned at 180. In either case, the difference is quite substantial. What is going on here?
rlee8394
Re: Well this seems rather strange, no?
« Reply #1 on: 28 Jun 2016, 06:57 pm »
Chaser,
More than likely your solid state amp is inverting, so when you set the HSU to 180 degrees, it's output is now in phase with the output of you solid state amp.
« Reply #2 on: 28 Jun 2016, 07:36 pm »
If the recording and amp are phase correct a 0º speaker will emit positive acoustic wave to front and negative acoustic wave to back.
Letitroll98
  • Too loud is just right
« Reply #3 on: 28 Jun 2016, 08:41 pm »
Chaser,
Shouldn't that be reworded either one way or the other?
