Cartridge voicing and our listening preferences.
0 Members and 1 Guest are viewing this topic. Read 1229 times.
felixscerri
« on: 28 Jun 2016, 09:05 am »
G'day all, rotating my Ortofon OM10 into service today it becomes apparent reasonably quickly that it isn't anywhere as 'warm' sounding as my Shure M97xE, yet that perception may not be as descriptive and accurate as it might seem.  I think that we can attribute the warmth of the M97xE to the slight upper treble roll off (the 'x' curve), and not bass boost.
Indeed the OM10 has good bass yet sounds to have a slightly 'brighter' sound overall and possibly not surprisingly, more detail, assuming optimum loading in all cases.  A few db of lift here and there at some critical frequency can radically change the way any given cartridge sounds in the context of the overall audio frequency response.
In terms of recovered detail the OM10 is clearly the better cartridge yet the warmth of the M97xE gives the M97xE a more solid and beefier sound that I personally find more satisfying.  Interesting indeed!  Regards, Felix.
neobop
  • BIRD LIVES
Re: Cartridge voicing and our listening preferences.
« Reply #1 on: 29 Jun 2016, 03:08 pm »
Hi Felix,
If the 2 carts were equalized for near identical frequency response, do you think the OM would still be more detailed?
Assuming you still run the M97 at 62K, you could load down the OM (like 40K).
neo
