noise back flow filter?
0 Members and 1 Guest are viewing this topic. Read 1834 times.
jhrlrd
« on: 21 Jun 2016, 05:00 pm »
I'd like to build or buy a small unit that would plug in series with each component's power cord to prevent generated noise
from going back into the other components. All my gear is plugged into a line conditioner already.
Any suggestions? thanks
jeffreybehr
Re: noise back flow filter?
« Reply #1 on: 22 Jun 2016, 12:01 am »
j, a simple 3-legged capacitive filter* at the component's AC-power inlet would reduce much high-frequency noise, incoming and outgoing.  Our resident experts probably will offer more-elegant solutions.
* Hot to common, hot to earth, and common to earth
G Georgopoulos
« Reply #2 on: 22 Jun 2016, 04:13 am »
this link has c-l-c bi-directional filters for live-neutral (2wire) and live-earth-neutral (3wire) mains EMI/RFI filters
if you build it your self make sure caps are rated ac mains voltage
http://www.audiomisc.co.uk/mains/filters1.html
jhrlrd
« Reply #3 on: 27 Jul 2016, 10:33 pm »
Great link for the basic RF filters. But what about noise in the audible range?
like hum/hiss/buzz coming out of the speakers.
I have a big issue with noise the plasma TV is generating coming over the speakers.
When the tv is off I'm still left with noise from the tube pre and amp, to a lesser degree, but audible from the listening seat.
