Martin J King O/B questions
0 Members and 1 Guest are viewing this topic. Read 2433 times.
mike noble
« on: 21 Jun 2016, 10:49 am »
I am going to build the Martin J King passive two way O/B but am having trouble finding a 30 mH inductor for the bass driver xover, does anyone out there know of a supplier, UK ? I have used a number of on line calculators for the xover and none have come up with a 30 mH inductor.
Would using a different combination of capacitor and inductor for the bass unit have an effect on the performance of the Fostex xover, and alter
the sound.
Is it practical to use two lower value inductors in series to make up the 30 mH inductor.
I would be grateful for any advice, but not to technical please.
Mike Noble
JerryM
  • Where's The Bar?
Re: Martin J King O/B questions
« Reply #1 on: 21 Jun 2016, 10:56 am »
Welcome to AudioCirlce, Mike.  :beer:
Guy 13
« Reply #2 on: 21 Jun 2016, 11:01 am »
A warm welcome to AudioCircle Mr. Mike.
Guy 13
« Reply #3 on: 21 Jun 2016, 12:38 pm »
the sound.
Mike Noble
I unknow this project but it seems unsual, 30mH will cut around 40Hz.
Maybe it is 3.0mH(cut around 400Hz) in this case you would contact Jeff at Sonic Craft very friendly service.
If 2.9mH(cut around 430Hz) fit yours needs Sonic Craft price are nice:
http://www.soniccraft.com/product_info.php/pair-alpha-core-16-awg-290mh-p-5092
mcgsxr
« Reply #4 on: 21 Jun 2016, 01:52 pm »
Welcome to AC, and thanks for your interest in OB!
We have a "special place" for folks like us here, so future questions might get answers in our OB Circle.
http://www.audiocircle.com/index.php?board=90.0
Phil A
« Reply #5 on: 21 Jun 2016, 04:59 pm »
Welcome to AC!
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #6 on: 28 Jun 2016, 07:25 am »
Where did you get 30 mH? We built based on the original article (but with FF85k) which specified 9 mH, worked fine. I see in part 2 he is now specifing 5 mH.
Do note that in his table in Part 2 he has the units uF & mH switched. There is a 30 uF cap.
dave
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #7 on: 28 Jun 2016, 05:34 pm »
I sent Martin a message about the swapping of the units on his table… he wrote back suggesting he needs to recheck the values of his LP filter as well, so you might want to postpone buying components.
dave
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #8 on: 29 Jun 2016, 01:17 am »
Martin has fixed the mistake in part 2 and it can now be downloaded.
http://www.quarter-wave.com/OBs/OB_Design_Part_2.pdf
You are now looking for a 9 mH choke.
dave
mike noble
MJK O/B Mikes reply
« Reply #9 on: 30 Jun 2016, 03:59 pm »
Thanks for advice re crossovers, unfortunately already ordered bits. have looked at part 2 on link, still the same as my original download with wrong figures. I will just go with crossover for alpha 15 from part 1 and use part 2 for FF125WK.
« Reply #10 on: 30 Jun 2016, 04:18 pm »
Greetings & Welcome to AC mike   :thumb:
