Hubba Hubba! Bugle, at last!!!
0 Members and 1 Guest are viewing this topic. Read 1301 times.
BillEpstein
« on: 6 Nov 2004, 08:02 pm »
I hung in there, Jim hung in there and the AC powered Bugle is making wonderful music. And the only HUM is coming from Glenn Gould! Thanks Jim. You answer E-mails as if there were no time difference.
http://home.att.net/~wsepstein/wsb/media/134428/site1245.jpg">
The last hurdle was indeed the input. But not a cable, the culprit was an RCA jack. I had used parts-box RCA's in keeping with the economy mode of the Bugle. But the right input hot lead was spinning in it's insulator, so......they're all replaced with Vampire gold over brass. $22 worth of RCA's in a $60 component! And while I was at it I ripped the wiring out of the Marantz 6100, re-did the grounds so the cart ground goes to a binding post separate from the chassis ground and installed 2 more Vampire RCA's and a Schurter IEC jack and ran Vampire 22 ga from the RCA's to the headshell lead loom.
http://home.att.net/~wsepstein/wsb/media/134428/site1244.jpg">
Now all I have to do is build a wider equipment stand................
