The "new" deck
0 Members and 2 Guests are viewing this topic. Read 13053 times.
Re: The "new" deck
« Reply #40 on: 6 Jul 2016, 05:08 pm »
Well, figured you'd get some knowledgeable input by now, but this will serve as a bump. While not an electrician given your geographical location safe rather than sorry might be the way to go. Worst case sink a temp ground rod, & run a jumper before you cut the existing. Then just delete the temp work when you get the new location set & reconnected.
Good to hear the innovative construction techniques didn't result in any issues.  :thumb:
thunderbrick
  • I'm just not right!
Re: The "new" deck
« Reply #41 on: 6 Jul 2016, 06:25 pm »
I like that idea!   :thumb:  I can punch a hole farther away and run a temp jumper before cutting the original.  I've got plenty of 12-2 wire around that'll do the job.
Or I can pull all the slack into the house and just bolt the 2x12 beam right on top of the wire.
