Sold... Cayin A100T Tube integrated amp $1500 OBO
0 Members and 1 Guest are viewing this topic. Read 1666 times.
MWS
« on: 10 Jun 2016, 10:02 pm »
I am selling this amp, it was wonderful with my La Scala's, but not enough power for my new speakers. I have not owned this for very long, unfortunately I bought it before I switched speakers. It is fantastic with high efficient speakers. This comes with remote. It is in excellent condition. Looking for $1500, not interested in trades. I will pick up the shipping if sold in the lower 48. I have all of the original packaging, so shipping should not be an issue. Papal OK. Let me know if you have any questions. Thank you for looking.
-Mark
The Cayin Audio A-100T is a remote-controlled tube integrated amp featuring a robust 100 watts per channel in Ultralinear and 50 watts per channel in Triode. Using KT-88 tubes, this beautiful, monster integrated amp imitates the Marantz 7C preamp and Marantz 9 amplifier. Talk about a marriage! Throw in the remote control and the price tag, and it really doesn't get any better than this. Oh, but it does! The A-100T includes a unique Soft-Start circuit with a 30-second turn-on delay to extend the life of those gorgeous, glowing tubes. The top deck of the unit uses an integrated volt meter for easy bias adjustment of the output tubes.
All Vacuum Tube Design - All Hand Made  System Vacuum Tube Integrated Amplifier w/Bias calibration system Power Output 50w Triode - 100w Ultralinear Tubes KT88 × 8, 12AU7 × 2, 6CG7 × 2, 12AX7 × 1 Frequency Response 10Hz - 65kHz THD 1% (1kHz) S/N Ratio 89dB Input Sensitivity 480mV, 900mV (pre in) Input Impedance 100K Ohms Output Impedance 4 ohm or 8 ohm Connections Power Consumption 280w Internal Construction Hand made with point to point wiring Chassis Heavy gauge hand rubbed and polished Soft Start Circuit 30 second delay for extended tube life Output Transformers Custom made potted, low impedance and wide bandwidth Power Supply Custom made potted toroidal Protection Tube plate fuse protects output stage Terminals WBT style speaker/Gold plated RCA × 4 Capacitors Premium Realcap & Nichicon Remote Control All functions including Ultralinear and Triode select Finish Silver faceplate Dimensions 17 3/8" × 8 1/2" × 15 3/4" (W×H×D) Weight 64 lbs. Protective Cage Included.
http://www.audiocircle.com/thumbnails/user/91182/20595/144663_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/91182/20595/144664_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/91182/20595/144665_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/91182/20595/144662_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/91182/20595/144655_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/91182/20595/144666_thumbnail.jpeg
« Last Edit: 16 Jun 2016, 01:21 am by MWS »
MWS
Re: Cayin A100T Tube integrated amp $1500 OBO
« Reply #1 on: 11 Jun 2016, 09:05 pm »
Motivated seller, could do $1300 shipped. Trying to avoid Ebay on this.
