LS36.5 won't power subwoofer
0 Members and 1 Guest are viewing this topic. Read 1515 times.
jhrlrd
« on: 10 Jun 2016, 07:52 am »
...this seems odd to me. all I get is faint hiss, a bit of bass, and nothing under around 80hz.
I tried the sub in output one and two. It drives the amp ok.
It's a JL audio E110 powered sub.
Any trick to getting this to work?
thanks
modwright
    • ModWright Instruments
Re: LS36.5 won't power subwoofer
« Reply #1 on: 10 Jun 2016, 03:05 pm »
If you are running two sets of RCA outs, that will work fine.  If you are running a set of RCA out sand XLR outs at the same time, it will load the output transformers unevenly and is not advised.  It should be able to drive the main and sub amp fine if both are RCA out.
Dan
jhrlrd
« Reply #2 on: 10 Jun 2016, 04:03 pm »
Yes, I'm driving both the amp and the sub with just the RCA outputs, you say it should be fine but isn't.
Is there something I can check?
I did swap outputs and the amp is driven fine by both outputs.
the sub does not work on either outputs.
nor does it work by itself without the amp hooked up at the same time, so it doesn't sound like an overloading issue.
I get a more usable signal hooking the sub to the tape output, but I have to turn the sub up way more than before.
the sub works fine when I hook it to another preamp.
does the preamp have an unusual output impedance that the sub doesn't like?
Or in the output circuitry, can something fry, then not allow 2 outputs to work at the same time?
« Last Edit: 11 Jun 2016, 03:16 am by jhrlrd »
