IDA-16 Assistance
0 Members and 1 Guest are viewing this topic. Read 2578 times.
duppie007
IDA-16 Assistance
« on: 10 Jun 2016, 06:38 am »
Hi All,
I am now a proud owner of an IDA-16 and love it. Couple of questions i have though and would appreciate your assistance:
1) I am using one subwoofer connected to the Analog out. Do i need to use a Y adapter or is there some intelligence in the unit to sent all LFE data if it detects only one Analog connected?
2) With the latest 6.55 windows 7 drivers and latest foobar the setup is not at all as per the documentation. A bit confusing. Is there a later setup guide available?
3) Would you recommend J. River Media Center  for DSD playback over foobar?
Many Thanks
Leon
rustydoglim
Re: IDA-16 Assistance
« Reply #1 on: 10 Jun 2016, 12:56 pm »
Normally subwoofer accept full range stereo inputs so connecting IDA16 line out to sub is fine.
I preferred to use JRiver Media Center as I find it easier to use than Foobar for DSD as well as other formats.
There is a setup guide on the download section.
srb
« Reply #2 on: 10 Jun 2016, 01:14 pm »
Is what you're saying that unlike many subwoofers that have stereo L/R line inputs, your particular subwoofer has only a single mono LFE input?  In which case using only the L or R analog output of the amplifier would only give you partial bass information from one channel.
If so, I guess your question still stands - is it OK to use a Y-adapter to combine the outputs into a mono signal (as I wouldn't expect the amplifier to "sense" that only one channel is connected and automatically output a mixed mono signal to either channel's output, which I believe was your other related question)?
Armaegis
« Reply #3 on: 11 Jun 2016, 04:56 am »
No. Never ever do this. A y-cable can not magically sum two signals together, and you run a good chance of damaging your source if you do.
duppie007
« Reply #4 on: 11 Jun 2016, 08:08 am »
Many thanks gents for the replies. It is a SVS sub with L and R low inputs. At the moment only R out from amp is connected to R low input of sub and it seems fine. Just wanted to know if i will be missing data from the L channel for the sub.
Do you find DSD over PCM (DoP) beter than native DSD playback when setup in JRiver?
Br
Leon
srb
« Reply #5 on: 11 Jun 2016, 08:25 am »
Yes, you're only getting bass from the R channel and should also connect the L channel.
duppie007
« Reply #6 on: 11 Jun 2016, 08:30 am »
Thanks, thought so. Now i must shop for another cable.
