Khartago Stereo SE input AC voltage range
0 Members and 1 Guest are viewing this topic. Read 2114 times.
anwar1965
« on: 8 Jun 2016, 03:04 am »
Hi, I bought a used Khartago stereo amp in good condition.  I live in a 240 VAC country where technically it is 230 +/- 10% but the actual incoming voltage is always at 240 or slightly higher.
Outside the packing box, it was checked at the 220 V, but at the back of the amp itself (near the IEC inlet), there is no label specifying input voltage range.  I checked the unified manual but there is no mention about this as well.  I sent email to [email protected] but have not received any reply.
I hope someone here can share his knowledge / experience on the allowable input AC voltage range.
Thank you in advance.
Anwar
klaus@odyssey
Re: Khartago Stereo SE input AC voltage range
« Reply #1 on: 13 Jun 2016, 04:37 am »
Hey Anwar,
OK, back from California...as for the unit, if the box is marked 220 / 240 V, then indeed it was an export piece and you're ready to go...as for your email,  don't have it  (maybe went into spam ???)
anwar1965
« Reply #2 on: 5 Jul 2016, 08:37 am »
Hi Klaus,
I sent you an email with a picture of the box and additional questions, just to ensure it will not be treated as a spam.
Thank you.
