IE Keyboard Shortcuts
0 Members and 1 Guest are viewing this topic. Read 1021 times.
« on: 4 Jun 2016, 11:48 am »
1) Close tab: Ctrl + W
2) Add current site to favorites Ctrl + D
3) Go to Home: Alt + Home
4) Delete browsing history: Ctrl + Shift + Delete
5) Help and Support: F1
6) Open the browsing history: Ctrl + H
7) Open a new tab: Ctrl + T
8] Enable Incognito (In Private): Ctrl + Shift + P
9) Print the current page: Ctrl + P
10) Refresh the page: F5
11) Switching between tabs: Ctrl + Tab
12) Show the application commands (address bar, frequent sites, etc.): Alt + D
13) View downloads: Ctrl + J
14) Search in the address bar: Ctrl + E
15) Search in a new tab: Alt + Enter
16) Search using copied text: Ctrl + Shift + L
17) Add "www." To the beginning and ".com" to the end of the text typed in the address bar: Ctrl + Enter
18) Display a list of typed addresses F4
19) In the address bar, move the cursor to the left until the next break in the phrase: Ctrl + Left Arrow
20) In the address bar, move the cursor to the right until the next break in the phrase: Ctrl + Right Arrow
21) Select text in the address bar: Alt + D
22) Activate a selected link: ENTER
23) Display the shortcut menu for a link: Shift + F10
24) Find something on the page: Ctrl + F
25) Go to the next page: Alt + Right Arrow
26) Go to previous page: Alt + Left Arrow
27) Go to the top of a page: PageUp
28) Go to the end of a page: Page Down
29) Return the items on a web page: Ctrl + Shift + Tab
30) Move forward through items on a web page: Ctrl + Tab + F6
31) Open a new document in Internet Explorer: Ctrl + O
32) Open a new window: Ctrl + N
33) Save the current page: Ctrl + S
34) Scroll page up: Up arrow
35) Scroll down the page: Down arrow
36) Stop downloading a page: Esc
37) Switch between full screen display and the common display: F11
38) Start the cursor navigation: F7
39) Copy the selected items to the clipboard: Ctrl + C
40) Cut the selected items to the clipboard: Ctrl + X
41) Paste the selected items from the clipboard: Ctrl + V
42) Select all items in a Web page: Ctrl + A
43) Open the menu Add to favorites: Alt + Z
44) Open the Favorites menu in the menu bar: Alt + A
45) Open the dialog box "Organize Favorites": Ctrl + B
46) Fix the Favorites Center and display your history: Ctrl + Shift + H
47) Show feeds: Ctrl + G
48) View History: Ctrl + H
49) Open the File menu: Alt + F
50) Open the Edit menu: Alt + E
51) Open the View menu: Alt + V
52) Open the Favorites menu: Alt + A
53) Open the Tools Alt + T
54) Open the Help menu Alt + H
55) Close tabs Background: Ctrl + F4
56) Open links in a new background tab: Ctrl + click
57) Open links in a new tab in the foreground: Ctrl + Shift + click
58) Duplicate tab: Ctrl + K
59) Re-open the last closed tab: Ctrl + Shift + T
60) Change tabs: Ctrl + Tab
61) Switch to the last tab: Ctrl + 9
62) Switching to a specific tab number: CTRL + number between 1 and 8.
GentleBender
Re: IE Keyboard Shortcuts
« Reply #1 on: 7 Jun 2016, 12:19 am »
Nice! Thanks FullRangeMan. Do these work on all versions of Internet Explorer?
« Reply #2 on: 7 Jun 2016, 03:28 am »
The article I read mention IE V11, I suppose there is no many earlier versions today as IE self upgrades.
Some these shortcuts works w/Firefox and others.
« Last Edit: 7 Jun 2016, 04:39 am by FullRangeMan »
