Wirelss HDMI for Cable TV (TWC)
0 Members and 1 Guest are viewing this topic. Read 985 times.
jtwrace
    • TIPP YouTube Channel
« on: 1 Jun 2016, 01:26 pm »
I have to setup a TV that's on the other side of the room where no cable jack is present.  Who has first hand experience with the "best" wireless transmitter/receiver to buy?  There are so many!
I'd like to not spend more than $200 if possible but do want it to work all the time and not have a crappy picture either.   :)
dolsey01
Re: Wirelss HDMI for Cable TV (TWC)
« Reply #1 on: 1 Jun 2016, 03:15 pm »
I have been using the Actiontec MyWirelessTV 2 to share a cable box between my guest room and my son's room.  They are about 15-20 feet apart, down a hallway.  It's not perfect but it does work well.
Occasionally I have to reset it but it's hard to say if it's the Actiontec or the Xfinity X1 box which it the culprit.
As far as picture quality, it looks identical to the cabled connection.  I got it from Jet.com with their initial 15% off discount so it was just over $150.
