SP-3&BDP-2
0 Members and 1 Guest are viewing this topic. Read 2119 times.
GASSMAN_67
SP-3&BDP-2
« on: 1 Jun 2016, 01:36 am »
I'm in the market for a new av processor, and am running the bda2/bdp2 compo, just curious if I used the dac in the SP3 instead of the bda2, if they're close performance wise.
Thx
Grit
  • - Garrett
Re: SP-3&BDP-2
« Reply #1 on: 1 Jun 2016, 10:56 pm »
I've been told the DAC in the SP3 is similar/close to the BDA-1, with an ever so slight lean toward the BDA-1.
wilsonij
  • BDP1>SP3>7B3s> Vandersteen Quatros
Re: SP-3&BDP-2
« Reply #2 on: 2 Jun 2016, 07:41 pm »
BDA-1 has a pair of 24-bit Crystal CS4398 DACs, one per channel in a dual-differential configuration
BDA-2 uses 32-bit AKM 4399s, adding support for asynchronous USB (up to 192k)
BDA-3 uses 32-bit AKM 4490s, adding support for DSD up to DSD256 (ie. quad rate DSD) up to 11.2MHz
SP-3 has the same DACs as the BDA-1
So I would expect that the "D to A" in the BDA-2 and BDA-3 will be "better" and "a lot better" respectively than the SP-3. but there would be little to choose between the SP-3 and BDA-1.
Of course the quality of the pre-amp will also be critical, and the one in the SP-3 is superb, so it's not simply a shoot-out between DACs...
...and there's the wider cost-benefit to consider; not only does the SP-3 have great DACs and great pre-amplication, but it's also multi-channel which therefore means multiple DACs and lots of digital processing too.
Personally, I went for the SP-3 as the heart of my system, including the provision of the D to A capability, and it's worked-out brilliantly. I've heard or owned units from most of the top performers - Classe, Theta, Meridian, Lexicon - and I've yet to hear anything that comes close to the Bryston SP-3.
Ian
« Last Edit: 2 Jun 2016, 09:25 pm by wilsonij »
GASSMAN_67
Re: SP-3&BDP-2
« Reply #3 on: 2 Jun 2016, 07:52 pm »
for 2 channel, I use a Krell EVO 202 pre-amp, so I was planning on routing the BDP-2 through the SP3, and then feeding my 202 pre the 2 channel audio...if that would work, and eliminate the BDA all together
alexone
Re: SP-3&BDP-2
« Reply #4 on: 2 Jun 2016, 08:34 pm »
hi, Ian!
i thought the BDA-2 supports 192/24 via its usb input?!?
al.
wilsonij
Re: SP-3&BDP-2
« Reply #5 on: 2 Jun 2016, 09:27 pm »
I've double-checked and you're right Al ! I have updated my post.
Lesson there is not to trust the accuracy of "Reviewers" but always go back to the Source of Authority :-)
Cheers -
Ian
alexone
Re: SP-3&BDP-2
« Reply #6 on: 3 Jun 2016, 07:45 pm »
 :thumb:
