Bryston speakers - time and phase coherent?
0 Members and 1 Guest are viewing this topic. Read 998 times.
techguy0192
« on: 31 May 2016, 10:17 pm »
Just curious if Bryston addressed time and phase alignment with their speaker line.  I've been a fan of speakers that are time and phase coherent designs for some time.  I'm aware that the speakers are not angeled to align the mids, highs, and lows; therefore was curious if some other method was being used to achieve this.  Not sure of the crossover type used in the Bryston's.  Am i correct in guessing that it's not a 1st order?  I'd love to hear Mr. Tanner's take on this subject.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston speakers - time and phase coherent?
« Reply #1 on: 31 May 2016, 10:42 pm »
Hi
Yes the time aligning is done in the crossover and they are very narrow slopes between the drivers.
There are a number of proprietary things we do but ultimately if you look at the Sound Power response that is what you actually hear when you play a speaker in a room that is the most critical measurement and the most meaningful you can make.  Problem is you need an anechoic chamber to do it - of which there are very few - we have our own :thumb:
james
