0 Members and 1 Guest are viewing this topic. Read 19782 times.
I was thinking of getting the 59AVi as I can get it for about $950 with a warranty, or $860 without.How much are the Onkyo's?I seem to recall that they were about $1600.
I don't know that any manufacturer has ever made any piece of electronics which didn't have at least a few with problems. That said, whether Denon is a sponsor or not, the Secrets testing objectively shows how well the various dvd players handle the tests thrown at them to evaluate deinterlacing performance, and those tests are thoroughly explained on the website. While people tend to view the results as some short-hand ranking of players in some absolute sense, the people doing the testing are pretty cle ...
I never read the review, nor do I know how they review things. As far as the complaints at AVS, I can't know if they're valid or not. The web is a well known repository for gripes, that I do know. Maybe those models are junk, maybe not- I can't say. You're the only person I've "talked" to that's had Q/C problems with them. Which means nothing- it doesn't invalidate your bad experience. And since those are somewhat expensive & newer machines, I simply don't know many people that have used one yet.U ...
I wish I could find some info on the bass management of the thing. I can only find one or two reviews, and they basically regurgitate the ad copy. Do actually have one, Ears? If so, are there separate programmable settings for SACD & DVD-A or one global setting for both? Every company to date has botched this- will Onk be the first to get it right? I honestly can't afford one right now, but I hope someone has finally figured out how bass management is supposed to work.
Has anyone added an aftermarket clock (e.g. Superclock III) to the Onkyo? Based on a shootout on audiogon, the SCIII apparently made a very significant improvement to the DV-50.
