Thread size of spikes on Kismet Beryllium Speakers?
0 Members and 1 Guest are viewing this topic. Read 2421 times.
audioguy213
« on: 29 May 2016, 05:30 pm »
Hi,
I am hoping to install Herbie's threaded gliders (http://herbiesaudiolab.net/spkrfeet.htm), on Kismet Ref BE speakers and wanted to confirm the thread size of the post on the spikes for the Kisme BE.
Here are some potential size options FYI:
Threads available:
8-32 (1/2" or 3/4" long)
10-32 (1/2" or 3/4" long)
1/4"-20 (1/2", 3/4", 1", 1.5" or 2" long)
5/16"-18 (1/2", 3/4", 1", or 2" long)
3/8"-16 (1", 1.5" or 2" long)
5/8"-11 (female for Salamander)
M5 (16mm long)
M6 (16mm, 20mm, or 25mm long)
M8 (15mm, 20mm, or 40mm long)
M10 (25mm long)
Metric thread pitch:
M5=0.8, M6=1, M8=1.25, M10=1.5
Thanks for any help!
sunnydaze
Re: Thread size of spikes on Kismet Beryllium Speakers?
« Reply #1 on: 29 May 2016, 05:44 pm »
Easiest way....
Take one of your spikes to local Home Depot or Lowes and find a nut that fits.
This will give the important stuff -- diameter and thread pitch.  Get whatever length you want.
audioguy213
« Reply #2 on: 29 May 2016, 05:47 pm »
Understood,
Don't have the speakers yet, trying to order the proper spike replacements because I have wood floors and this will make placement tweaking easier from the jump, and avoid me killing the wife's floors.
I suspect Klaus or one of the people who have already made such a replacement will know off hand.
audioguy213
« Reply #3 on: 5 Jun 2016, 09:29 pm »
To answer my own question, there are no holes for spikes,
I went with Giant fat Gliders and some regular gliders to test for tilt.
klaus@odyssey
« Reply #4 on: 13 Jun 2016, 04:39 am »
No threads at all...you can do that yourself if you want with some insets,  but I usually don't like it that much...
