Communication system, for headsets?
0 Members and 1 Guest are viewing this topic. Read 1647 times.
Folsom
« on: 26 May 2016, 07:39 pm »
Hi guys,
If you had a small group of people that needed to communicate while moving around inside a building doing stuff, what would you use?
This looks like an ideal headset, but there's nothing ideal about PTT radios for their fidelity. Also an option to be able to leave it open, instead of PTT, would be nice. In the past cellphones have been used but it's a really stupid way to go, too, since they get chucked at the end or a project.
Thoughts?
jtwrace
    • TIPP YouTube Channel
Re: Communication system, for headsets?
« Reply #1 on: 26 May 2016, 07:41 pm »
Can you define "doing stuff"?
Folsom
« Reply #2 on: 26 May 2016, 08:03 pm »
Typing mostly, but also pushing stuff around, etc. It's in hospital work.
GentleBender
« Reply #3 on: 27 May 2016, 11:54 am »
I don't know how many you need or how big of a building/space you will be using them in. But how about two-way radios? These might be a bit overkill,but it is only one example of many options. http://smile.amazon.com/Motorola-CLS1410-Walkie-Headsets-Charger/dp/B010THN5O6/ref=pd_sim_107_23?ie=UTF8&dpID=51uLnfAa0dL&dpSrc=sims&preST=_AC_UL160_SR108%2C160_&refRID=1K94QRXQW8J3M459SV67
Folsom
« Reply #4 on: 28 May 2016, 03:05 am »
Not necessarily overkill. The biggest issue is trying to achieve cellphone like quality.
Odal3
« Reply #5 on: 28 May 2016, 01:21 pm »
Don't understand why the phones have to be thrown away at the end. If still an option, what about using personal phones with one of the free conference call services and just have the line open the whole time
Folsom
« Reply #6 on: 28 May 2016, 05:59 pm »
They only get used periodically. It could 6 months to 2 years at a time. Currently the client buys whatever it is that gets used. They don't have any right to ask people whom may or may not have personal cellphones to use them.
GentleBender
« Reply #7 on: 28 May 2016, 06:23 pm »
I can't think of anything that matches a decent phone's call fidelity.
