0 Members and 1 Guest are viewing this topic. Read 16127 times.
Just put in the Silver NextGen (with less than 50 hrs on it) and it is an improvement over the Silver Eichmann (fully burned in) it replaced.As predicited, there is an increase in transparency (which means more detail) and the bass is tighter and more dynamic.Looks like I know which version I am keeping...George
dac, preamp, and amps are fully balanced.
Quote from: zybardac, preamp, and amps are fully balanced.Does that include the Placette active, or only the Bent?DU
Just curious as to build wise what makes the Silver NextGen better than the Silver Eichmann?
Seems like the performance should be near identical ???I'm trying to decide which RCA connectors to get with my Pulsar interconnects.I went to Eichmann's and WBT's sites where I read everything and downloaded spec sheets and it appears to me that the core design and materials used for both the Bullets and Nextgens are near identical, so it therefore seems logical that the performance of these two are near identical ???
Quote from: mcaJust curious as to build wise what makes the Silver NextGen better than the Silver Eichmann?Seems like the performance should be near identical ???I'm trying to decide which RCA connectors to get with my Pulsar interconnects.I went to Eichmann's and WBT's sites where I read everything and downloaded spec sheets and it appears to me that the core design and materials used for both the Bullets and Nextgens are near identical, so it therefore seems logical that the performance of these two are near identical ???
What experience have you all had matching power & speaker cables with the Pulsars?
