0 Members and 1 Guest are viewing this topic. Read 6374 times.
The room is an issue. Dimensions are a bit odd. It's more like a hallway than a room. It's 9' wide, 30' long, and 7 1/2' high. But, I've lots of broadband bass traps in the corners, on the ceiling and the first and secondary reflection points. The folks at GKI say I have pretty good response for a non-purpose built room. Let's not forget, however, you go to war with the room you have, not the room you wish you had, or something like that.Doc
I owned my model 3s for 22 years. They started as 3s then were upgraded to 3A status and then finally to Signatures. I enjoyed countless hours of satisfying listening from them. However, having the Treo CT for a month now I can't believe how much smoother, more finely resolved the sound is now. If you can wait till you are ready for the Treos that would be the way to go. Again, nothing at all against the 3A Signature. They are, like all of Richard's speakers, an amazing value!If you want some wisdom from the master himself, go tho the Vandersteen Audio site and Click on "Ask Richard" and then use the pull-down menu to get to floor standing speakers. If you cruise through there a bit you will get a solid sense for Richard's feelings about the speakers in question.Good luck and happy listening either way you go.
The treo I have read are really different speakers all together not sounding like the model 2 or model 3 and as such some people perfer the 3aSig over the TREO
