Better SQ after separating PRE that was stash under DAC ??
0 Members and 1 Guest are viewing this topic. Read 1347 times.
Yitshak
Today I got head up from our local Bryston dealer
That My BDP2's arrived safe and tomorrow they will bring them to me.
Great I'm so happy.
So... In my main setup I had the BP6 stash under BDA3
Always and before that I had the BDA2 seat above it.
Anyway I didn't want to stash BDP2 as well didn't look nice to me (3 units one above the other)
So I took the BP6 to the lower level.
Like so:
This way it will be only BDP above BDA.
After I connect it again and power all I hear sound different.
Better define bass line with subtle shifting on the bass notes and much more
natural high mids and highs almost like a room presence.
Anyone experience somethings similar Or is it just me so exited about the
Coming BDP's that I start to imagining things?
Though I really don't think so ...
My wife hear it as well without concentrating to much,
it's quite notisble improvement.
« Last Edit: 16 May 2016, 09:42 pm by Yitshak »
zoom25
Re: Better SQ after separating PRE that was stash under DAC ??
« Reply #1 on: 16 May 2016, 09:32 pm »
I don't have all your Bryston equipment, but I do have the BDP-1 (files:WAV).
In its current rig, it's being used with: Dangerous Music Source w/ Teradak LPSU, Amphion (Amp100/One15), and Sennheiser HD 800. I have noticed something similar to what you're describing. Spacing your components apart is always good, along with isolation (vibration + EM/RFI).
However, I also noticed a change in sound in my rig, when I never moved anything, except for rewiring my power cables into a new outlet as I was running out of plug spaces. Before, my audio and power cables were spaced apart and everything sound fine. When I moved them to the new outlet, the power and audio cables (digital and analog ICs) were running beside each other. As soon as I played it, everything sounded compressed and muddy. I actually thought I blew something out at first. It took me quite awhile to figure out what had actually happened. Apparently, others have also run into this problem before. Now, I always make sure to keep both the digital (AES) and analog cables away from power cables.
Perhaps, another thing to look at when you get the BDP-2.
Yitshak
« Reply #2 on: 16 May 2016, 09:50 pm »
Thanks zoom25,
Now that I think of it I did separate cables and
Also move the TV SAT box to the other side with its RF cable...maybe
It contribute also.
R. Daneel
« Reply #3 on: 17 May 2016, 06:50 am »
Stash or stack?
Yitshak
« Reply #4 on: 17 May 2016, 04:17 pm »
Stash or stack?
guess oops is in order :)
Thanks took a note (not my local language )
