0 Members and 1 Guest are viewing this topic. Read 1541 times.
Are the new cubed amps recommended for use with electrostatic or planar speakers (e.g. Martin-Logan, Sanders, Magnepan). Can the new amps handle the very low impedance of electrostats at higher frequencies?TIA
Thanks, James.That's reassuring. I am thinking about upgrading my aging (but still wonderful) 3B and ML SL3s to a 4B Cubed and possibly a pair of Maggie 1.7is or 3.7is. I don't think I can do the jump to 4Bs and Sanders speakers all in one go. Do you think the 4B3s can drive the 1.7is or 3.7is adequately or do I need to go to a pair of 7B3s? (The room is about 20 x 12.). I am also considering Bryston As for an almost all Bryston system, but I assume that the amps will work with those! As a M-L owner, I noticed that you conspicuously said nothing about the new Cubeds with them. I suspect there is a reason for that.Thanks.
