Cat 5 Source
0 Members and 1 Guest are viewing this topic. Read 4646 times.
Escott1377
Cat 5 Source
« on: 12 May 2016, 01:14 pm »
I don't know anything about purchasing Cat 5 cable, but I stumbled on a speaker cable that uses them and would like to try as a little DIY project.
Can anyone please recommend a source in the US that can provide equivalent to this?  http://www.maplin.co.uk/p/cat-5e-utp-network-cable-solid-low-smoke-zero-halogen-blue-priced-per-metre-vb20w
Thanks in advance!
Phil A
Phil A
Phil A
Re: Cat 5 Source
« Reply #3 on: 12 May 2016, 01:22 pm »
There are also lots of US distributors of raw wire and supplies including newark.com, Allied Electronics and Mouser
Speedskater
  • Kevin
Re: Cat 5 Source
« Reply #4 on: 12 May 2016, 02:22 pm »
For speaker cables, Cat3 is as good as Cat5. You can find surplus or end of reel Cat3 almost for free.
srb
Re: Cat 5 Source
« Reply #5 on: 12 May 2016, 03:07 pm »
Home Depot (and Lowes also, I believe) sells a few different types of Cat5e not only in 100/500/1000 ft. spools, but also by the foot if you don't need that much.
Escott1377
Re: Cat 5 Source
« Reply #6 on: 12 May 2016, 03:11 pm »
Thanks all.
I found a relatively inexpensive solution from Monoprice.
Escott1377
Re: Cat 5 Source
« Reply #7 on: 30 May 2016, 11:48 am »
Can anyone tell me if the Cat 5 patch cable will be made of the same materials as the bulk order I purchased?
I completed my speaker cable build and am happy with the results.
I have a friend who has requested that I make him 2 pair, and I only had enough left for 1 set.
The cable needs to be pure copper and not tinned.
Trying to avoid purchasing another 250 ft when I only need about 60 ft.
Thanks in advance.
srb
Re: Cat 5 Source
« Reply #8 on: 30 May 2016, 01:10 pm »
Again, I would just go down to the local Home Depot or Lowe's where you can buy un-tinned solid copper CAT5 by the foot.
jea48
Re: Cat 5 Source
« Reply #9 on: 30 May 2016, 01:15 pm »
Thanks in advance.
As a rule factory made, massed produced, patch cables are made from stranded core wire. I assume the 4 pair cable you bought is solid core.
