Hooking up a laptop to a plasma TV
0 Members and 1 Guest are viewing this topic. Read 1441 times.
PhilNYC
« on: 4 Nov 2004, 02:55 am »
I've got a laptop (Toshiba A75) that I'd like to hook up to my Panasonic plasma TV.  The laptop has a regular 15-pin monitor output, and the TV has that as an input.  However, the laptop output is assuming that the TV is a regular 4:3 aspect ratio, and it won't display on the full 16:9 without stretching the output.
Is there a way to configure the laptop so it takes advantage of the widescreen?
dave_c
« Reply #1 on: 4 Nov 2004, 03:40 am »
You should be able to go into the properties of your video adapter and change the resolution to match that of your TV.
To get to Video Properties:
Right Click on Desktop -> Properties -> Settings Tab
From there you should be able to choose your display resolution.  You may see a drop down where you can choose between display 1, and display 2.  I believe that if select display 2 in the drop down and configure that to the resolution you want, it should display automatically when you connect the TV.
PhilNYC
« Reply #2 on: 4 Nov 2004, 04:36 am »
Dave,
Thanks, looks like that did the trick!
Phil
