0 Members and 1 Guest are viewing this topic. Read 6545 times.
Looks like Omega has a few options worth exploring for under 1000.00 to 1500.00 in total pair cost, and have heard [read] good things about them here on Audiocircle.
Hi megabigeye,I also built a Bottlehead amplifier - a Stereomour. It's 3.5 w/ch. Recently, I was also looking for a DIY monitor with reasonable sensitivity and a flat pack and found the Diysoundgroup. Here is a kit that might fit your needs:http://www.diysoundgroup.com/coaxial-speaker-kits/volt-10lx/v10-volt-lxe-kit.htmlYou can also see my build thread of the Fusion Alchemy here:http://www.audiocircle.com/index.php?topic=139584.0These speakers have a sensitivity of ~94 dB/w. The first one is less expensive (~$370/pair including flat pack - a little more than your budget) and has greater bass extension. My experience was very positive and I can highly recommend the Diysoundgroup's offerings.Good luck!
I wouldn't mind something a little more involved in the building process (in fact, I would really enjoy it), but it has to basically snap together. Clamps are okay, but I don't have room for drills, routers, CNC machines, or even, for that matter, wood shavings and sawdust.
