Easy way to adjust balance with SP3
0 Members and 1 Guest are viewing this topic. Read 1009 times.
WillyP
« on: 7 May 2016, 01:09 am »
Hi James,
From time to time it becomes necessary to adjust the balance of a certain CD or DVD (Left / Right or Front / Center / Back). Is there an easy way to adjust the balance (temporarily) without going to the menu of the SP3? Is it also possible in 2-CH BYPASS mode?
Willy
  • The Demo is Everything!
    • http://www.bryston.com
Re: Easy way to adjust balance with SP3
« Reply #1 on: 7 May 2016, 02:01 am »
Hi Willy
Not sure on that - email Stan and he will know [email protected]
james
WillyP
« Reply #2 on: 14 May 2016, 07:29 pm »
Unfortunately, the answer is no. You have to go into the menu if you want to control the balance. With my integrated amp I can change the balance on the fly from my chair.
Kind regards,
WillyP
