FS: Verastarr 5-channel Silver Reference Braided 1M RCA Interconnects
0 Members and 1 Guest are viewing this topic. Read 761 times.
Corradobrit
Excellent set of highly praised Verastarr Silver Reference 5-channel 1M (3.3 ft) Interconnects. The silver coated copper cables are terminated with high quality WBT 0147 locking RCA connectors.
Includes remainder of the 10 year transferable warranty and supplied 'birth certificate' from Verastarr.
Retailed for $1749. Asking $645.
FREE USPS PRIORITY MAIL SHIPPING CONUS
Email for international shipping quote.
Details from the Verastarr website:
"During development we spent much time experimenting with different types of wire; including Pure Silver, Single crystal Copper, and Silver plated Copper. We have finally settled on our favorite which is Silver plated Copper.
Not all Silver plated Copper is equal. Depending on the geometry and the materials used, even the same metal can have very different sounds. After much trial and error, we have come up with what we think is a true reference interconnect. As you know, when you are putting together a reference system, symbiosis between components and cables is very important. We had to create a design that worked well with many different manufacturers. This could then remove the cable part of the equation when designing a true reference level system. Our cables have been utilized with every imaginable type of component stretching from 3-watt, single-ended triode designs to 1000-watt, solid state designs and from $100 CD players to $10,000 DACs.
Our cables are known for a very accurate and natural signal integrity. Even though we employ the use of silver, there is never a hint of "tizziness" or brittleness on the top end. We have found the use of silver plated copper to be extremely good for tight, musical, low-frequency notes. Not only that, but the midrange is extremely transparent, neutral, and devoid of colorations. These cables will truly tell you what your system is made of.
Each piece is handcrafted one at a time here in the U.S.A. under strict quality control. Only pure silver solder is used."
Review from an end user:
"For those looking for the very best in a multi channel analog interconnect, be sure to evaluate Verastarr's Silver Reference 5.1 (channel) cable. After spending time with the other multi channel cables available, this is the only one that has genuine Reference aspirations. A clear winner for anyone with a reference quality system in need of a dedicated 5.1 channel cable."
Matthew Cramer | Bel Canto Design
