New technology/design question
0 Members and 1 Guest are viewing this topic. Read 1411 times.
charmerci
« on: 4 May 2016, 06:53 pm »
I just bought a new laptop. My other one is 5 years old. So what's the difference inside - and how does it get smaller and much lighter?
Speedskater
  • Kevin
Re: New technology/design question
« Reply #1 on: 4 May 2016, 07:58 pm »
Most likely the new laptop consumes less power.
Because there is a big market for small inexpensive SMPS (power supplies) lots of companies are into making them.
richidoo
« Reply #2 on: 4 May 2016, 09:20 pm »
The construction of the processor chips has changed. The size of the printed semiconductors is thinner now, and the resolution of the printed semiconductors themselves has improved. This is called the "process" size, that's the pixel size used to draw the individual parts on the chip die. Current commercial CPUs are 14nm process, but Intel is heading toward 5nm by 2020. 10 years ago it was 10 times bigger. The smaller the process, the less current it consumes. So the voltage of the chips can be lower and the heat they waste is lower making the whole product smaller, cooler, lighter, etc. Cell phones are driving this, of course. It affects memory chips, GPUs, everything getting smaller, so they can fit it all inside your eyeball.  :icon_lol:
http://www.10stripe.com/articles/what-does-process-size-mean.php
charmerci
« Reply #3 on: 4 May 2016, 09:28 pm »
 :thumb:
Yup! This one is lighter and is definitely running cooler.
..and you mean fits on your eyeball.
https://www.technologyreview.com/s/515666/contact-lens-computer-like-google-glass-without-the-glasses/
