Table Platform Question
0 Members and 1 Guest are viewing this topic. Read 3381 times.
JDUBS
« on: 4 May 2016, 12:44 am »
Hey Guys
I'm strongly considering one of these:
http://www.grizzly.com/products/Surface-Plate-Stand-18-x-24-/G9658?utm_campaign=zPage
after having seen others on this forum using it in conjunction with a 3" granite slab:
http://www.grizzly.com/products/18-x-24-x-3-Granite-Surface-Plate-No-Ledge/G9654?utm_campaign=zPage
I actually like the industrial look of it.  Plus the level adjustments are nice to have.
But, would I be better served with a maple slab of the same dimensions?  Granite vs. maple?
Jim
Letitroll98
  • Too loud is just right
Re: Table Platform Question
« Reply #1 on: 4 May 2016, 12:49 am »
Ha!  Halfway through your post I was thinking, "why not maple"?  So yes, my vote would be for the maple.
xsb7244
« Reply #2 on: 4 May 2016, 01:01 am »
A lot of info on Michigan Maple for turntable.
https://dawnsdepot.com/
Bob2
« Reply #3 on: 4 May 2016, 01:13 am »
I'm using the granite surface plate and highly recommend it.
No vibrations are transmitted to the turntable. It is a great price for a "lab grade" plate.
Mine arrived in perfect condition. Make sure you can handle the weight...
Maple just doesn't have the mass  of granite, it costs less than maple....but maybe that is the problem???
vinyl_guy
« Reply #4 on: 4 May 2016, 01:24 am »
Jim,
I just had one of these built. Maple and cherry with Daedalus Isolation Devices. Works great and it is beautiful.
http://www.audiocircle.com/index.php?topic=142590.msg1521483#msg1521483
Syrah
« Reply #5 on: 4 May 2016, 04:09 am »
I had this stand and I still have the surface plate, actually two of them.
The problem with the stand is that the steel rings.  I don't think it's ideal for a TT stand - but I do agree it looks cool.  Shame - I sold mine for almost nothing.
If I could sum up my TT platform experience, it would be that each TT is different in how it responds.
My Linn? Ultra lightweight and hard, things like aluminum honeycomb were best.   VPI Classic?  Three layers of bloodwood with the middle layer stuffed with lead shot was best.  My Teres and my VPI Prime, 1/2" granite epoxied to 1" MDF was the best.
Others with better knowledge than me can chime in, but I think sprung tables like hard lightweight platforms, and heavy likes heavy.
If you're able to experiment with platforms, that would be my advice.  They are both TT and system (and probably flooring, and taste?) dependent.
If you have a kitchen counter place nearby, see if they can give you an ugly unfinished scrap piece of granite in the right size (because it's the finishing and shipping that cost the bucks), epoxy it to a piece of MDF and try it under your TT.  If it sounds bad, throw it away.  If it sounds good, get a nice finished piece of granite and repeat.
Some shelf "experts" seem to say that when you're dealing with the really thick granite, it's tough to deaden the ringing.  But I think others say, if it's thick enough it rings less anyway.  Practically, those surface plates are crazy heavy, so it's pretty tough to experiment with unless you have a few strapping sons you can call upon to help with moving it about.
You could try the same thing with a maple butchers' block.  If it doesn't sound good under your TT, you can dice a mean vegetable on it.
