Trio15 A5000 – Field Coil Open Baffle Speaker
0 Members and 1 Guest are viewing this topic. Read 5785 times.
beowulf
« on: 3 May 2016, 07:26 am »
The TrioA5000 will debut in Munich High-End 2016.  These look pretty promising, using the Wolf von Langa A5000 Field Coil Drivers.
The Trio15 A5000 speakers are a variation of our modular Open Baffle architecture and Leonidas Crossover. They  feature four major components:
PureAudioProject Trio15 Open Baffle Platform feat. 15″ Aluminium Frame and Baffles.
4 x OB-A15Neo 15″ Woofers.
2 x A5000 Drivers.
Leonidas Crossover with components for Trio15 A5000.
Then you will need a current/power source for the field coil drivers.
General Specifications
•SPL: ~96db measured in a typical room
•Frequency Response: 34hz – 20,000Hz (all Trio15 models)
•Impedance: 3.5 to 8ohm
•Amplifier Rated Impedance: 8ohm
•Recommended Amplifiers: 3.5w (Tubes SE) and higher (Tubes, Solid State, Class D)
I thought I saw some pricing earlier today, but now it seems to have been removed and while they were not cheap, they seemed pretty reasonable for what you're getting in the package.  What do you guys think?
mirekti
Re: Trio15 A5000 – Field Coil Open Baffle Speaker
« Reply #1 on: 4 May 2016, 05:04 am »
Do you remember what you saw? :)
beowulf
« Reply #2 on: 4 May 2016, 05:51 am »
I want to say it was in the 8~9K range, but I can't say for sure as I just glanced at the webpage for a moment before I left for an errand I had ... then once I returned to the website the $$$ amount was missing.
I'm pretty sure the A5000 field coil is a modified driver by Lowther.
nicoch
« Reply #3 on: 8 Jul 2016, 07:52 am »
some nice pic
PDR
  • May the best man win
« Reply #4 on: 8 Jul 2016, 01:01 pm »
The lower pic is the Tang Band 1808.
I'm building(DIY) a pair with the Tangs.....have received the 15" Neos from PAP already.
If their as good as everyone says, I'll prob upgrade to the Voxativ AC1.6
Grant Fidelity sells all the components....including the A5000 field coil.....they're out of my price range.
 http://shop.grantfidelity.com/Speaker-Drivers/
nicoch
« Reply #5 on: 8 Jul 2016, 10:27 pm »
yes is TB I'm sure you love this OB
