Interested in OB
0 Members and 1 Guest are viewing this topic. Read 2269 times.
mkane
Interested in OB
« on: 2 May 2016, 03:38 pm »
  Three tube amps in the house. 25w El34 pp & two 2a3 SET's. Audio Nirvana has high sensitivity full range speakers. Opinions on using some of their offerings. Currently have modded Cornwalls in the main room.
Blackmore
Re: Interested in OB
« Reply #1 on: 2 May 2016, 04:20 pm »
If you're thinking about using them as stand alone open baffles, then you'll need to search the drivers with a high Qts greater than .7   Only a few of his offerings would work for you mainly the 12" and 15" variations.  NOW if you were open to the idea of using your Cornwalls as a bass cabinet and using this drivers as a mid/tweeter in an open baffle, you have lots of choices.  Friends who have heard David's drivers have been generally impressed with them.  Seems like they favored the 10" version in a box, but I'd go smaller if you're thinking about letting the Cornwalls do bass duty. You've got plenty of amps to do biamping, so grab a Behringer or mini dsp crossover and have some fun.  Good luck with your project.
Poultrygeist
« Reply #2 on: 10 May 2016, 12:01 pm »
These were my first serious OB's: Wild Burro Audio Betsy's over Eminence Alphas. Ran the Betsy's full range sans crossover with a SET amp and a SS amp on the Alphas. Later removed the low pass filters and switched to a single 100 watt plate amp on the Alphas.
Poultrygeist
« Reply #3 on: 10 May 2016, 12:03 pm »
This guy uses some large AN's in his OB's. Great SET amp collection.
http://glowinthedarkaudio.com/thoughts-opinions.html
mkane
« Reply #4 on: 10 May 2016, 09:23 pm »
 thanks for the link
