Audio/Video Gear and Systems
The Discless Circle
toddbagwell
Squeezebox Duet
Squeezebox Duet
0 Members and 1 Guest are viewing this topic. Read 1091 times.
Escott1377
Squeezebox Duet
2 May 2016, 02:43 pm »
Can anyone recommend a linear power supply for the Duet? I have heard that upgrading the power supply makes a noticeable difference.
Please let me know and thanks!
Escott1377
Re: Squeezebox Duet
2 May 2016, 02:57 pm »
I found the CI Audio option @ $279.00.
If anyone has a more budget friendly option to suggest, it would be greatly appreciated.
mcgsxr
Mark in Burlington, Canada
Re: Squeezebox Duet
Reply #2 on:
2 May 2016, 04:37 pm »
By memory there may be some Teradak units on eBay.
If you're looking for affordable units you likely have to troll the classifieds here, A'gon etc.
I found a used CIA unit that I am using for my Touch. Great piece.
mdconnelly
Re: Squeezebox Duet
Reply #3 on:
3 May 2016, 05:01 pm »
The 9v iFi power supply might be a very nice, low-cost match for the Duet.
http://ifi-audio.com/portfolio-view/accessory-ipower/
Caveat... I have not tried it, but have heard that the 5v works well for the SB Touch.
Last Edit: 3 May 2016, 10:17 pm by mdconnelly
Charles Calkins
Re: Squeezebox Duet
Reply #4 on:
3 May 2016, 05:09 pm »
IMHO an upgraded power supply sometimes makes my squeeze box 3 sound a wee bit better.
I get much better results by connecting the SB3 to a good DAC. through the coax out on the SB3.
Cheers
Charlie
The Discless Circle
toddbagwell
Squeezebox Duet
