SOLD!--Parasound Halo P5 : Preamp - DAC w/ Bass management + Remote - Black.
0 Members and 1 Guest are viewing this topic. Read 1888 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
What to do when you have multiples of a kick-ass swiss army knife pre-amp?   Offer one up for sale :)
Parasound Halo P5      $SOLD!!! Shipped within the CONUS
In short it's one of my favorite Go To pre-amp/DAC combo units.  The feature list is impressive and it has performed very well with all sorts of Gear that I've paired it with.     It's still a current production model from Parasound.    It packs quite a bit of USABLE functionality in one neat package.   Excellent DAC, Bass management functions are solid, Phono Stage with MM/MC support ( and it's actually quite good),  front panel aux has 12db gain ( for your phone or tablet this is perfect) .   HT Pass through, Balanced Input /Output  blah blah blah etc etc...
Here's the feature list direct from their site :
  • Burr-Brown PCM1798 DAC with USB, Optical and Coax inputs
  • Coax and optical accept all sampling rates up to 192 kHz, 24-bit
  • USB accepts up to 96 kHz, 24-bit
  • Incoming jitter on all three digital inputs is significally attenuated with an effective clock recovery system
  • Analog Bass management with high and low pass crossovers
  • Home theater bypass input for surround sound integration
  • Front panel subwoofer level control
  • 5 RCA line level inputs
  • 1 XLR balanced input (parallels Input 5 RCA jacks)
  • Phono input for MM & MC cartridges with 100 Ohm or 47k Ohm load
  • Front panel Aux input with automatic +12 dB gain stage
  • Balanced XLR and RCA left and right outputs1 balanced XLR and 2 RCA subwoofer outputs
    • 1 balanced XLR and 2 RCA subwoofer outputs
    • Bass & treble controls with defeat from remote or front panel
    • Headphone jack with 10 ohm output impedance
    • Rear panel IR input and IR loop output jacks
    • 12 V output to trigger power amplifiers and other devices
    • Automatic turn on with 12 V trigger or AC power
    • Fixed level record output
    • Premium motor-driven Alps potentiometer volume control
    • Left/Right Balance control
    • Remote control with discrete on/off power buttons
    • 0.5w standby power consumption meets Energy Star spec
    • Rack mounting adapter available (Model HRA 2 sold separately)
    • Available in silver or black finish
My second P5 is paired with a Threshold S/300, Sony CDP XA-7es,  MacMini running Audirivana,  Apple TV,  and  Luxman T02 Tuner  It's handling Bass management for a set of  Celestion SL6  and Snell PS10 Sub ( filtered at 80hz) - sounds damn good.
Here's a frontside pic of the unit for sale , set up with an Audire Otez Power amp and EAD T-1000 CD Transport.  P5 is the DAC in this set up via coax.
« Last Edit: 2 May 2016, 02:22 pm by Bostown »
Berd
I'm interested in your pre amp.
Let me know how to contact you to work out details.
John
Bostown
John
I sent you a private message in response.
Bostown
Halo P5 is now spoken for and marked as SOLD!
I have speakers up for sale as well as cables and more coming.
Audire Forte Amps will go up in the amp section later today ( 5/2/16)
