Recommendations for Audiophile Server
0 Members and 1 Guest are viewing this topic. Read 4477 times.
stump4545
« on: 26 Apr 2016, 03:44 pm »
looking for a top notch Audiophile Server with only about 1TB of HD space and USB output to my Modwright Eyse DAC.
Tablet control would be cool but not necessary.
Any suggestions of where to being my search?
thank you
sfox7076
Re: Recommendations for Audiophile Server
« Reply #1 on: 26 Apr 2016, 03:48 pm »
Price range?  Check out the Salk Stream for midlevel.  Lampizator Komputer for over the top.
stump4545
« Reply #2 on: 26 Apr 2016, 04:46 pm »
under 5k.
stump4545
« Reply #3 on: 26 Apr 2016, 07:27 pm »
what does a Lampizator Komputer cost anyway?
dminches
« Reply #4 on: 26 Apr 2016, 08:15 pm »
Are you handy enough to build your own?  If not, I would look at the aurender line.
stump4545
« Reply #5 on: 26 Apr 2016, 11:10 pm »
Any dealer recommendations for the Aurender Line?
Anyone here have these Aurender servers?  they look pretty neat.  better then a mac mini rig?
thanks!
maxboy00
« Reply #6 on: 26 Apr 2016, 11:56 pm »
I purchased an Aurender N-100H from Essential Audio, the owner, Brain is very knowledgeable about the Aurender line...he mostly post in the Aurender thread over on CA. That thread is a long one but hits most of the bases. Since I'm still waiting for my DAC to ship, I have not been able to use the server yet.
Also make sure the USB port on the MW Elyse is USB 2.0 audio complainant....if not then you will need a converter.
dminches
« Reply #7 on: 27 Apr 2016, 12:21 am »
I used an Elyse with an Aurender N100H so you are set there.  Excellent combination.
jarcher
  • It Just Sounds Right
« Reply #8 on: 28 Apr 2016, 01:30 am »
thanks!
Definitely better than a Mac mini.
These are pretty plug and play, so your local / closest dealer would be best (unless they are douches). Where are you located?
ACHiPo
« Reply #9 on: 28 Apr 2016, 07:00 am »
Look at the HAL MS-3 if you want a PC-based server.  I use one for my library and an Aurender S10 as my player.  Rich Hollis is a member here and a great guy.
http://www.dagogo.com/hollis-audio-labs-ms-1-music-server-review
dminches
« Reply #10 on: 28 Apr 2016, 11:40 am »
Other than store music what does the HAL do that the Aurender doesn't?  The Aurender is a server and player.
HAL
« Reply #11 on: 28 Apr 2016, 11:45 am »
Well it can also run room and speaker correction and any other Windows based software for audio.
Stripped down Windows 10 64bit OS for use.  It also allows you to rip your CD collection to your library with the internal DVD drive.
orientalexpress
« Reply #12 on: 28 Apr 2016, 02:55 pm »
Hal MS-3 play Large ISO Files without a problem and can handle Large library 25 tb nas or 2-5tb external HD .
rollo
  • Rollo Audio Consulting -
« Reply #13 on: 28 Apr 2016, 03:36 pm »
  Plus one on HAL music server. The best I have heard in computer audio period.
charles
