It is my opinion with the processing power of the mac mini vs and air, you should go with the mini. You can always stick a SSD in it and you can add RAM yourself in the bottom.
GentleBender is correct about the RAM being soldered on the logic board. I cannot think of any good reason for this other than to lock in the buyer to Apple's inflated RAM prices, but there you are.
Note that on the 2010-2014 Mac Mini's, you can easily (and reversibly) convert to DC power if desired by using the Uptone Audio Mac mini DC-Conversion / Linear Fan Controller Kit and connecting it to a 12V linear power supply or battery. (This also replaces the fan controller, which is one of the electrically noisier components in the machine.) Some people have gone so far as to max out the RAM, boot from an SDHC card, and then run from a RAM disk, so as to avoid having even the SATA bus powered.I agree with the recommendation to retrofit any Mac Mini with an SSD, if it didn't come with one initially. Aside from lowering the physical noise of the machine, it also reduces the total heat generation, which therefore lessens the need for the fan.Soldering the RAM is one done to enable a thinner laptop design, and is a feature common to every "ultrabook" style laptop that I know of, both Mac and PC. See the new HP Spectre for reference. (SO DIMM slots are actually very thick in comparison to the total thickness of this style of laptop.) In addition, soldering the RAM gives the manufacturer the freedom to place the modules anywhere on the logic board they like, easing the layout design.The current Mac Minis have soldered RAM because they use a laptop derived logic board.
