FS: Pair of Liberty B2B 100 amps
0 Members and 1 Guest are viewing this topic. Read 687 times.
nickd
« on: 22 Apr 2016, 07:23 pm »
$1995.00 ea. or $3900. for the pair. Local pick up in San Diego or buyer pays shipping $75.00 ea. 50 states
They have been my reference amps for 2 years now. A super transparent soundstage and dynamic range that competes with the "ultra" amps at stratospheric prices. What I like most is that they have a wonderful tone from the Mosfet's that brings out some of the color and texture that solid state amps sometimes miss. The robust build and dependable drive of Solid state and the soundstage and tonal colors of tubes. These are sweet amps indeed. list was $2500. ea. I believe now they are up to $2995.
Nice reviews on line.
B2B-100 Technical Specifications
◾Class A/AB Power amplifier
◾Stereo Power output into 8 Ohm = 110WPC @< 0.1% THD Power output into 4 Ohm = 200WPC @ <0.1 %THD
◾Mono Block Operation Power into 8 Ohm = 350W @0.1% THD*
◾Mono Block Operation Power into 4 Ohm = 600W @0.1% THD*
◾Power Consumption 200W in High Bias, 100W in Low Bias @ Idle. 700W max
◾Input Impedance 75K Ohm RCA, 36K Ohm Balanced (18K Ohm per leg)
◾Dimensions 19" W x 5.75"H by 16"D
◾Weight 50 lbs.
*Requires both nodes be driven; i.e. fully differential preamplifier.
I had to down size a bit to an integrated. My loss is someone's gain. I also have a PBN Olympia LX with a Tent resistor ladder volume control if anyone is interested. It is a true reference piece.
