Help with my PJ to amp connection
0 Members and 1 Guest are viewing this topic. Read 1017 times.
stlrman
« on: 15 Apr 2016, 09:21 pm »
Dvd to PJ is connected through Hdmi.
Dvd has coaxial out , amp has coaxial in , however I can't figure out how to select the coaxial input using the remote/ menu .
Amp is Onkyo tx 8050
Thanks for any help!!
youravhandyman
Re: Help with my PJ to amp connection
« Reply #1 on: 15 Apr 2016, 09:55 pm »
My past experience with Onkyo had me performing those functions from the face of the receiver.  Multi function nob let you select the input source on them.  Hope that helps.  Mine was old and just at the beginning of on screen setups.  Dang good amp, though.
stlrman
« Reply #2 on: 16 Apr 2016, 03:03 am »
Thank you. We will give this a shot .
