0 Members and 1 Guest are viewing this topic. Read 15539 times.
Yeah, that's why I said "spec'd as". I suppose I should download one of those turntable speed apps, no idea how accurate they might be. But right now I'm redecorating a new listening room so that will have to wait. There's no love for the Traveler either here or at VPI it seems, but it's a really a nice sounding table, much better than the HW 19 Jr I previously owned.
Trust me the only real way to do this is put a record on the platter, than this strobe shown in link right on top of it, drop your needle because you have to compensate for "drag" which absolutely changes the speed by as much as 1 rpm in some cases, put your weight in the center if your using one as it also creates a speed change, and proceed to check both 33, and 45 rpm.
Well I downloaded an Android app and it claims my VPI is running at 32.6 rpm, again, don't know how accurate that is. Which I think calculates to .13% slow, three hundreds of a percent off the spec. of .1%. The app only goes to tenths so there's no way to check the wow and flutter beyond that it never wavered off that 32.6 number, but I won't know about the claimed .02% figure with this app.
I use turntabulator. I can hear some records as 'slow' at 33.1. I think acceptable variation comes down to preference (and how much you spent on your turntable).
