***SOLD***exaSound E20 MK III .082 Clock PRICE REDUCTION!
0 Members and 1 Guest are viewing this topic. Read 3551 times.
hifial
  • Ambassador, Sound Galleries & Taiko Audio
    • Sound Test
As can be seen the label became smeared. It happened when using footers under the DAC. It still shows the model and serial number.
***SOLD***Up for sale is my exaSound E20 MKIII .082 Clock DAC. This is one of the best DAC out there and is hard to beat when used with a quality external power supply. It is in great condition and I am the original owner. The non decimating volume control works perfectly because it doesn't drop bits.  It will also drive any Amp direct, no need for a Preamp. But you can use it with a Preamp and set the volume to 100 takes the volume out of the mix, it is now direct to use with a preamp.  My unit contains an upgraded clock (.082ps rms clock) usually reserved for $15,000+ DACS. This was an offer to only some exaSound MK III owners by the designer/owner of exaSound and not an open public option. So only a limited number of MK III have the upgraded clock.
The unit comes with an external brick style power supply. However, I have been using a Paul Hynes Design SR3-12 (2.5amp steady-3+amps-12v) Power Supply with GREAT RESULTS! Paul Hynes is a world renowned designer of Audio power supplies. I am looking to sell the Hynes PS with the E20 MKIII .082 as a package but will also consider selling them separately.
Some info about the E20:
E20 Mk III supports three additional sampling rates over previous models: DSD64 - 3.072MHz, DSD128 - 6.144MHz and DSD256 - 12.288MHz.
exaSound is one of a few DAC that supports Native DSD using USB for ALL DSD rates. Most only support higher rate DSD using DoP with USB if at all
384kHz/32bit maximum PCM sampling rate. Native support for DXD 352.8kHz master files.
ES9018 Sabre32 reference DAC chip from ESS Technologies.
Asynchronous USB Interface eliminates jitter caused by unstable computer timing.
OS X and Windows ASIO custom high-performance drivers.
Automatic sampling rate switching.
.082 ps rms master clock. Jitter minimization is achieved by using 3 three precision oscillators.
11 power filtering stages.
Galvanic isolation between the USB subsystem and the DAC circuits eliminates ground loops noise and blocks computer-originated interferences.
Second generation headphone amplifier that can bring the best out of the most accurate headphones.
Simultaneously driven, gold plated balanced (XLR), and unbalanced (RCA) line outputs.
Two S/PDIF inputs provide jitter reduction and superb D/A conversion when used with CD transports.
The e20 MKIII DAC can be programmed to work with most IR remote controls. Includes an Apple Remote
I have all the original accessories for the E20 MK III .082 - power supply, cables, cable adapter, manual, box, etc.
For the SR3-12 I have the Custom DC Cable and box.
I will also sell them separately;
E20 MK III .082 - Asking $1,700.00 Available
SR3-12 - Asking $450.00 SOLD
Confirmed PayPal only. Plus shipping and PayPal fees. Shipping USA only.
I will post photos soon.
A correction on the SR3-12, it is 2.5 amps steady but can output more on peak.
I am reducing the price of both. Posted 5/29/16
For the SR3-12 I have the Custom DC Cable and box. SOLD But the E20 MK III .082 is still available
***SOLD***E20 MK III .082 - Asking $1,500.00 Available
SR3-12 - Asking $425.00 SOLD
I will also ship to Canada. If you have a confirmed PayPal I will consider shipping elsewhere but please have some feedback.
« Last Edit: 11 May 2016, 12:50 am by hifial »
mooncrikit
Great day to ya. What is the msrp on each piece in this package? Thanx, MOONCRIKIT
audio.bill
According to AudioStream's review the DAC retail was $2,899 plus $100 for the optional upgraded clock. I apologize if the price has changed since the review, just trying to help. GLWS Al!
hifial
    • Sound Test
Well Bill is correct. However the E22 MK II, which replaced the E20 MK III, with the same clock goes for quite a bit more.
As for the list of the SR3-12 with shipping from Europe and import fees it came to around $600.
hifial
    • Sound Test
Photos added and bump.
hifial
    • Sound Test
Price reduced and bump. See main add for price change.
mikeeastman
hifial
    • Sound Test
Sale pending on the Paul Hynes SR3-12 Power Supply
The exaSound E20 MK III .082 is still available.
hifial
    • Sound Test
Paul Hynes SR3-12 Power Supply is sold.
The exaSound E20 MK III .082 DAC is still available. New REDUCED Price is $1,500.00
J Payton
Re: exaSound E20 MK III .082 Clock PRICE REDUCTION!
« Reply #9 on: 9 May 2016, 07:28 pm »
You have PM
JP
hifial
    • Sound Test
Re: ***SOLD***exaSound E20 MK III .082 Clock PRICE REDUCTION!
« Reply #10 on: 11 May 2016, 12:51 am »
***SOLD***
Both the exaSound E20 and the Paul Hynes is SOLD.
