LGK 1.0 Center Channel
0 Members and 1 Guest are viewing this topic. Read 1317 times.
Keithh
« on: 11 Apr 2016, 09:07 pm »
Can the LGK be built any other way for center channel use? Say with keeping the 4-1/2" width but making it 8" high and 12" deep.
Or mounting the speaker in the middle and laying it on it's side so it's 4-1/2" H by 12" W by 8" D. Think I read that Danny said that won't work
but just wanted to make sure before I start building.
Was completely surprised how good the LGK's sound with a SVS 12" sub, so I will try a small HT system with them.
Danny Richie
    • http://www.gr-research.com
Re: LGK 1.0 Center Channel
« Reply #1 on: 11 Apr 2016, 09:10 pm »
Or mounting the speaker in the middle and laying it on it's side so it's 4-1/2" H by 12" W by 8" D. Think I read that Danny said that won't work but just wanted to make sure before I start building. Was completely surprised how good the LGK's sound with a SVS 12" sub, so I will try a small HT system with them.
Yeah, the performance of the LGK will surprise you. I had to make a small theater system using them myself.
If you need to lay it on its side then you can move the driver to the middle of the box if you want. No problem.
