Remote Kit Question
0 Members and 1 Guest are viewing this topic. Read 1592 times.
mgalusha
Remote Kit Question
« on: 1 Nov 2004, 04:04 am »
Kevin,
I have been asked about installing one of your remote kits inside a preamp. I had a look at the kit at RMAF and it seems nicely done. Can you provide the dimensions of the board so I can determine how much room will be needed and thus if this is feasible?
The board wasn't very large if I remember correctly but dimensions would be great. I looked at your site but didn't find this information. Looking at the pictures and going from memory I'd guess it's about 1.5 x 4 inches.
Mike
Kevin P
    • http://www.diycable.com
Remote Kit Question
« Reply #1 on: 1 Nov 2004, 05:56 pm »
Mike,
Yes... thanks for asking.  I've updated the web page to reflect the size.
The actual size is 35mm wide by 102mm long (1 3/8" x 4") so your pretty close on your guess.
The board can be located anywhere in the chassis as the IR port can be attached via a ribbon cable.
mgalusha
Remote Kit Question
« Reply #2 on: 1 Nov 2004, 11:39 pm »
Kevin,
Thanks for the reply. I will order the kit today or tomorrow.
Mike
YoungDave
remote question
« Reply #3 on: 15 Jan 2005, 04:40 am »
Any way to get a remote for Noble pots?  My pre uses 2 - 25k Nobles.  Might be nice to have so I can set vol & bal from listening position, but I don't think I want to go to the Alps pot & I really think its 25k I need anyhow...
Kevin P
Remote Kit Question
« Reply #4 on: 16 Jan 2005, 09:26 pm »
The remote board is good with any motorized pot that can work with 5VDC to control the motor.   I'm not sure there is a motorized Nobel easily available.   You would have to do some searching.   I've only used the Alps units to date.
