SOLD!! Spatial Audio Hologram M2 Turbo $1400
0 Members and 1 Guest are viewing this topic. Read 2064 times.
davisoly
« on: 6 Apr 2016, 08:04 pm »
These Spatials are special. These open baffles offer a tidy, clean design, and project a sound that is to fall in love with.
 Their Controlled Directivity System claims to reduce room interaction, allowing consistent results in most any room environment. I have to agree. I never had to employ bass equalization or special speaker placement to contend with boominess or bass drop-off. People viewing their performance at audio shows also express their ability to automatically adapt to varying and difficult room conditions . Hologram's 95dB Sensitivity allow the use of low powered amplifiers. I drove them easily with a pair of Decware 2-Watt Zen SET amps. “A stunning 3D sound field is generated by the point source, wide range compression driver”, they say. They are truth tellers. The speakers present a great and believable stage.
I purchased these not three months ago from a gentleman who maybe had just burned them in. They look as new and ship in the original packaging. I am selling because my own prejudiced ears could hear too-little improvement over my own personally built Zen open-baffle pair. My own ZOBs are spectacular. And these are that good, and maybe even a tad smoother.
Here are the specs:
MSRP: $2500
Type:  Compact 2-way, point source, open-baffle, dynamic driver, controlled directivity
Chassis:  5 layer Aluminum Composite / HDF
Driver compliment:  Two 12 inch mid/woofers, one wide bandwidth compression driver
Crossover:  800Hz - Passive -  Hologram Network Technology
Frequency Response:  43Hz - 20kHz  +/- 3dB in room response
Sensitivity:  95dB - averaged across 200Hz to 5kHz at 1M - on axis
Impedance:  4Ω nominal, 3 Ω minimum, low phase angle
Dimensions:  27T x 16W x 3D inches, 35 lbs.
Thanks for looking.
Lynn
« Last Edit: 12 May 2016, 10:54 pm by davisoly »
dpatters
Re: FS: Spatial Audio Hologram M2 open baffle speakers - $1600
« Reply #1 on: 7 Apr 2016, 12:01 pm »
You might want to post this in the speakers category rather than accessories.
davisoly
« Reply #2 on: 7 Apr 2016, 12:22 pm »
Thanks for the heads-up. It is done.
Lynn
