Mye Stand for DWM
0 Members and 1 Guest are viewing this topic. Read 2481 times.
Paddlefoot
Mye Stand for DWM
« on: 4 Apr 2016, 03:37 pm »
hi, has anyone got one of these for their DWM, did it work well. would love to hear from you, thinking about getting one. thanks Greg
SteveFord
Re: Mye Stand for DWM
« Reply #1 on: 6 Apr 2016, 11:25 pm »
Can anyone help?
Paddlefoot
« Reply #2 on: 7 Apr 2016, 09:16 am »
thanks Steve, i went ahead and ordered one. i`ll let you know how well it did. i have two DWM`s so i can compare one with and one without. Greg
SteveFord
« Reply #3 on: 7 Apr 2016, 08:50 pm »
Please do, that should be an interesting comparison.
Paddlefoot
« Reply #4 on: 9 May 2016, 12:45 pm »
Ok i will give you my short findings between the Mye stand for the DWM and the stock wooden Magnepan base. the Mye stand clearly brings the DWM up a notch or two. The bass line is much easier to follow, details that kinda go missing are now fully realized.  the bass is much tighter and fuller sounding up to the mid bass area. the DWM works up in the 250 HZ range and that range sound is clear and more attached to the Minis.
The sound of a single DWM on a Mye stand sounds far better than two DWM on the Magnepan wooded base. If you have a Mini Maggie system, you should check these out. I will have more later on them later this week.
NIGHTFALL1970
« Reply #5 on: 9 May 2016, 02:56 pm »
Thanks for the review.  I am considering getting Mye stands for my 1.7s.
