FS: Conrad Johnson LP70s Tube Amp
0 Members and 1 Guest are viewing this topic. Read 7467 times.
djkzk
« on: 2 Apr 2016, 11:10 pm »
For sale: a beautiful Conrad Johnson LP70S tube power amp with Teflon CJD coupling capacitors; 70 watts/channel. US$ list $7500, asking $3250 obo.
The amp is in excellent functional and cosmetic shape. Factory supplied tubes are in like new condition. I however am rating it as in "Very Good Condition" due to me being the second owner, otherwise this is in "Excellent condition".
The LP70S is a very open transparent and smooth sounding amp. This amp combined with CJ's Premier 16 preamp is the best sounding system I have had yet; now due to a speaker change I am going in a different direction. This amp has only been used in a smoke/pet/child free home.
Shipping, Paypal ...extra. Only trade I would consider is a Coda 15 or 15.5 amp.
The amp is packed in the original box plus I have double boxed it to ensure safe shipping. Tubes have been removed and separately bubble wrapped. Shipping weight: 62 lbs. Upon request I have additional pictures to show amp without tube cages, packing of amp etc. Please also note, the one picture of the top that shows a couple white dashes toward the rear is actually the sun coming through the window blinds. If you have any other questions please ask.
You can review my other feedback on Audiogon as djkzk, AudioAsylumTrader as iwillfish4free and ebay as djkz.
Product Information: This conrad-johnson linearized-pentode amplifier is designed to meet the needs of industry professionals and audiophiles who seek audio perfection for their reference systems.
All LP amplifiers share the same basic audio circuit. This circuit consists of three stages. The input signal is amplified by a triode amplifier. The signal is then direct coupled to a cathode coupled phase-inverter.
This high current, triode phase-inverter stage provides a balanced, low impedance drive to the output stage. Output power is developed by 6550 output tubes, chosen for their musical accuracy, high power, and reliability. Each channel of the LP70S uses one pair of 6550s to produce 70 watts per channel.
The output tubes are operated in ultralinear configuration which offers an optimal combination of high power and low distortion. The massive conrad-johnson transpectral output transformers have intricately interleaved wind-ings designed for extended bandpass and high phase linearity. A small amount (about 12 dB) of loop negative feedback reduces distortion and achieves a sufficiently high damping factor to control reactive loudspeaker systems.
Separate, low impedance, discrete dc power supply regulators are provided for the input and phase-inverter stages, preventing the output stage from modulating these stages through the power supply. These power supplies are designed to maintain a rock solid supply at all audio frequencies. The main power supply reservoir uses a bank of massive custom polypropylene capacitors. No electrolytic capacitors are used in any of these power supplies.
These amplifiers require no complicated adjustments or specialized equipment to main­tain. To assure continued peak performance, the owner need only make a simple bias adjustment when new tubes are installed. Built in LED bias indicators allow the user to easily make this adjust­ment.
« Last Edit: 16 Apr 2016, 07:10 pm by djkzk »
JerryM
  • Where's The Bar?
Re: For Sale: Conrad Johnson LP70s Tube Amp
« Reply #1 on: 3 Apr 2016, 03:04 am »
Beautiful amp.
djkzk
« Reply #2 on: 3 Apr 2016, 03:49 am »
JerryM, thanks and more so for posting a few pics for me.  I don't know what I am doing wrong but every time I try to post a pic it just ends up being a thumbnail pic.  Any ideas?
djkzk
« Reply #3 on: 3 Apr 2016, 03:55 am »
OK, here is more of the pics.  Figured out that Windows 10 and Explorer do not work right now with loading our pics, had to jump to Chrome.
polyglot
« Reply #4 on: 6 Apr 2016, 03:49 am »
Great design and sound! Plenty of choice for tube rolling too! I own a pair of LP140 which is derived from the LP70, rolled the tubes and the main fuse. Bumped up the SQ a notch.
djkzk
« Reply #5 on: 6 Apr 2016, 04:07 am »
Yes I have heard from other LP70s owners who have had great success rolling tubes and also upgrading from the 6550 to KT120s.  I bet those 140s are sweet though.
polyglot
« Reply #6 on: 7 Apr 2016, 03:39 am »
I had various 6550s, (Tung Sol) KT120 but, to my ears, prefer the Golden Dragon KT88 Reissue. (CJ does not approve the new KT150, sic).
The KT120 has better bass but lacks the midrange that both 6550 and GD KT88 offers, the latter being more balanced throughout the spectrum.
Hope your LP70 will find a new home soon!
djkzk
Re: FS: Conrad Johnson LP70s Tube Amp
« Reply #7 on: 25 Apr 2016, 05:45 pm »
bump
djkzk
« Reply #8 on: 14 May 2016, 06:06 am »
Great tube amp for someone.
DrMorbius
« Reply #9 on: 16 Sep 2025, 04:03 am »
Beautiful amp, for sure! Has it been sold?
