** SOLD ** Pass Labs X5 multichannel power amplifier
0 Members and 1 Guest are viewing this topic. Read 1952 times.
edwyun
For your consideration is a rare Pass Labs X5 for multichannel home theater use (although it can also be used for just two-channel). You don't find these every day, but they are still probably one of the best multichannel amps out there. It operates in Class AB, but the first 25W (e.g., 20%) operates in Class A consistent with Nelson Pass's typical design.  It is in excellent condition and works well.  Sounds even better.  Only reason I'm selling is that I don't view/listen to HT as much these days due to time. What time I do have, I listen to two-channel.  I've had it since 2008.
From the manual:
- Bandwidth:  DC (-0dB) to 100kHz (-3dB)
- Power:  125W for each of five channels into 8 Ohms.
- Gain:  30dB.
- Max output voltage:  +/- 50V.
- Max output current:  +/- 10 amps.
- Dynamic range:  140dB (random noise floor to peak output).
- Input impedance:  22 kOhms balanced.
- Both both RCA and XLR input connections.
- Comes with power cord, XLR grounding plugs, printed manual, and original box.
MSRP was $4500 USD in the late 2000s.  I am asking $2500 plus actual shipping, OBO.  I will pick up the Paypal fees.  Paypal only and shipping only to CONUS.  About 85 lbs and ships from 07068.
I hope it goes to a good home.
« Last Edit: 14 Aug 2016, 01:25 am by edwyun »
edwyun
Re: ** SOLD ** Pass Labs X5 multichannel power amplifier
« Reply #1 on: 14 Aug 2016, 01:25 am »
Sold
