0 Members and 1 Guest are viewing this topic. Read 3113 times.
Try pulling the speakers out. Put the left one in front of the wall divider, and the right one straight out. Pick up a couple of roles of fiberglass to stack in the back corners. Put a comforter/quilt over the TV. If this helps, you can look at making traps that are more attractive. Move your speakers out for critical listening, and back when not in use. A couple more pictures from other angles might help us as well. Good luck. Getting the room right is time consuming, but has the potential for great reward.
Thanks for the replies.Naturally I hadn't even thought of pulling the speakers out farther. I will probably add some absorption material here and there and see what happens after I move them out a bit.Thanks much, very helpful.
