Flat! Pack builders
0 Members and 1 Guest are viewing this topic. Read 2226 times.
apollophono
Flat! Pack builders
« on: 31 Mar 2016, 04:07 am »
I'm not sure if this is the right place soooooo.  Here goes!
I'm looking for a list of flat pack manufacturers to fit various
speaker kits.  I'm interested in the GR-Research LGK kits
or XL-S kits.
I'm a cheap bastard and I'm not worried about looks per se.
I'm all about sound.
Mike
jseipp
Re: Flat! Pack builders
« Reply #1 on: 31 Mar 2016, 04:22 am »
Danny Ritchie probably still has ready-made LGK cabinets, and they're cheap :).  The GR Research board will point you to other resources, as well.
apollophono
« Reply #2 on: 31 Mar 2016, 04:42 am »
Thanks JSEIPP.  I saw the the LGK flat pack options and they are really cheap.
I was also asking because I may not go that way and I wanted to see if there
are companies that will build flat packs for any kit that I choose.  For example
I see that http://www.wilmslow-audio.co.uk will build them, but they are in
the U.K.  Are there any in the U.S.?
mlundy57
« Reply #3 on: 1 Apr 2016, 03:04 am »
You could probably find a cabinet maker in your area who would cut the pieces for you.
Right now the only flat packs available that I'm aware of for any of Danny's speakers are the ones Jay (Captainhemo) is building for the dual and triple OB subs and the NX-Oticas.
I think jseipp is correct about Danny still having some LGK 1.0 cabinets available. If I remember correctly, they need a little rework though.
Mike
