SOLD Von Schweikert LCR-15 Center
0 Members and 1 Guest are viewing this topic. Read 1683 times.
mca
« on: 30 Mar 2016, 10:01 pm »
Very nice condition LCR-15 for sale for $350 $300 including shipping and PayPal.
SYSTEM TYPE: Shielded three-way full range dialogue/general purpose speaker system. One woofer is used for bass only, while the second woofer is used for midbass and midrange frequencies. Can be mounted horizontally or vertically.
BASS LOADING: Aperiodic Pressure Release design using 100% stuffing density. Note that the vents are not bass reflex ports, but act as pressure release orifices. Can be placed inside a cabinet.
BASS DRIVERS: 2pc --5.5" heavy- duty bass/mids with cast frame, cellulose acetate pulp cones impregnated with mica substrate and damped with a carbon fiber/resin polymer, Low Distortion Motor system, butyl rubber surrounds, long throw spider, high temperature voice coil and magnetic shielding. This new driver design has a very natural sound quality with inaudible coloration or distortion.
TWEETER: 1" - composite silk/polymer resin dome with Ferrofluid liquid cooling, high temperature voice coil, Low Distortion Motor design, and magnetic shielding. This tweeter is very musical, without harshness, even at high volume levels that would cause "standard" tweeters to fail.
CROSSOVER: Global Axis Integration Network (synthesized steep-filters with phase-consistent behavior) with 300 Hz and 2.2 kHz crossover points. This crossover design has been engineered to radiate sound in a wide "bubble" instead of a "beam," so that phase and frequency response does not radically change off-axis. The finest parts have been hand selected, including polypropylene capacitors and premium air core inductors.
BINDING POSTS: High quality "audiophile" five-way binding posts with rhodium plating.
FREQUENCY RESPONSE: Baffled mounting (inside equipment cabinet): 32 Hz-20 kHz; (free air: 60 Hz-20 kHz +/- 2dB).
SENSITIVITY: 88 dB @ one watt/one meter anechoic, 91 dB measured in room with boundary gain.
POWER HANDLING: 8 watts min., 200 watts peak.
IMPEDANCE: 8 ohms nominal (7 ohm minimum, 19 ohms maximum). SET friendly!
WEIGHT: 28 lbs packed for shipping, 20 lbs raw.
DIMENSIONS: 17.5" Wide x 10.25" Deep x 7.5" High (horizontally placed).
« Last Edit: 29 May 2016, 11:37 pm by mca »
mca
Re: FS: Von Schweikert LCR-15 Center
« Reply #1 on: 5 Apr 2016, 04:24 pm »
Bump!
mca
« Reply #2 on: 22 Apr 2016, 02:37 am »
Price reduced to $300.
mca
« Reply #3 on: 30 Apr 2016, 05:57 pm »
Bump
